× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
geofilter fail xr500 destiny
blaisual
Tutor
i have the firmware xr500 v2.3.2.114 but the geofilter does not working on the game destiny 2,does someone have a solution or know howto fix it. have already tried a lot and tried but nothing worked and no flush cloud.the flush cloud says thatR-app will not work for a certain period of time.
please help.
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 16
Netduma-Liam
NetDuma Partner
Re: geofilter fail xr500 destiny
We have recently pushed an update for Destiny so you should be able to filter by servers now. We are aware that there appear to be a couple of authentication servers that can still be blocked so you may need to manually allow any 'blocked' connections that appear in Geo-filter when you try to find a game. Once we've pushed a new cloud update, you shouldn't need to do this.
Also, the error you're seeing in Ping Heatmap is normal, it will have successfully sync'd with the cloud, it just threw an error becaues it took a bit longer than it was expecting.
Message 2 of 16
Dunaz
Guide
Come faccio a capire se il mio xr500 blocca i server, sembra che continua a ignorare geofilter, guida i alla soluzione grazie
Message 3 of 16
Netduma-Liam
NetDuma Partner
Abbiamo una guida nella nostra knowledge base che dovrebbe aiutarti in questo:
http://support.netduma.com/support/solutions/articles/16000077072-dumaos-optimal-settings-guide-geo-...
Facci sapere se hai ulteriori domande!
Message 4 of 16
Dunaz
Guide
Great job guys, the router filters destiny perfectly thanks
Message 5 of 16
Stylhz
Dunaz come hai fatto a filtrare i server riesci a fare le free win?
Message 6 of 16
Shaxi
What settings are you using please
Message 7 of 16
Netduma-Fraser
NetDuma Partner
@Stylhz No, non puoi, questo serve per filtrare i server, non per abbinare solo / contro i compagni di squadra.
@Shaxi place your radius over an area with servers and you will be able to force them.
Message 8 of 16
Malver
Liam, ese par de servidores a los que haces referencia permiten bloquear jugadores fuera de rango en destiny 2 como antes de la actualización? donde estan situados estos servidores para probar el geofiltro?
Muchas gracias.
Message 9 of 16
Netduma-Liam
NetDuma Partner
Ya no creo que puedas bloquear a jugadores específicos con DumaOS solo, ya que Destiny ahora se ha movido al emparejamiento basado en servidor y no de igual a igual.
Message 10 of 16
Malver
no entiendo eso...emparejamiento de igual a igual.
que yo sepa destiny2 nos conecta a un servidor a todos los jugadores y luego el propio servidor busca jugadores con un mismo nivel para emparejarlos..
eso lo an cambiado?
Message 11 of 16
Malver
como es posible eso si dentro de nada van a hacer crosplay con los de pc .... y cada jugador decidira si quiere jugar con la otra plataforma o no
Message 12 of 16
Malver
cuando entro en modo crisol me pone...
evaluado guardianes ....
buscando guardianes...
eso significa que ?
Message 13 of 16
Netduma-Liam
NetDuma Partner
Eso es correcto, así es esencialmente como funciona su sistema de emparejamiento ahora. Anteriormente, utilizaban el emparejamiento de igual a igual, en el que los jugadores no estaban todos conectados a un servidor central, sino que estaban conectados a un host específico, o todos se comunicaban entre sí de manera que no había un host específico.
Al igual que con otros juegos, Geo-filter ahora funciona con Destiny asegurándose de que esté conectado a su servidor más cercano que le ofrece las mejores conexiones a la red SDR. Esto significa que se está asegurando de tener la mejor conexión posible. Ya no se puede usar para asegurar que eres el único jugador en el lobby o para que controles qué otros jugadores pueden conectarse a tu lobby, pero este nunca fue el uso previsto de Geo-filter independientemente. ¿Cuáles son sus configuraciones actuales de filtros geográficos?
Message 14 of 16
Malver
hola
en el modo competitivo de crisol de destiny2 se vasa en puntos de 0 a 5500 si tienes 380 puntos no te empareja con jugadores de 4600
y en modo de osiris que es mas competitivo va por victorias derrotas.. si empiezas el contrato tienes 0 victorias 0 derrotas y no te empareja con jugadores que tengan por ejemplo 1 derrota con 5 victorias.
entonces no entioendo.
desde que juego hace 5 años la busqueda de jugadores es igual una por puntos y otra por victorias derrotas.
y eso no lo an cambiado ahora
Message 15 of 16
Netduma-Fraser
NetDuma Partner
Esa puede ser la parte frontal de cómo funciona, pero el sistema de redes backend ha cambiado para depender de los servidores.
Message 16 of 16
Discussion stats
  • 15 replies
  • 3075 views
  • 1 kudo
  • 7 in conversation
Announcements
Orbi WiFi 7
