× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
haserl CGI Error XR1000
nSparkz
Hi I can't log in to my netduma os I get the following error.
I also tried using http://192.168.1.1/adv_index.htm
to update the firmware it shows no updates...
haserl CGI Error
Failed to readline from 'config get DumaOS_Theme_Version'
Message 1 of 4
nSparkz
Re: haserl CGI Error XR1000
I restarted the router with http://192.168.1.1/adv_index.htm now I can't log in with the admin username and password as I normally do in netduma os...
Message 2 of 4
antinode
Guru
> [...] XR1000
      https://community.netgear.com/t5/x/bd-p/en-home-nighthawk-pro-gaming-routers
> [...] to update the firmware [...]
   From what to what?
> [...] now I can't log in with the admin username and password as I
   "can't" is not a useful problem description.  It does not say what
you did.  It does not say what happened when you did it.  As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
Message 3 of 4
Netduma-Fraser
NetDuma Partner
What happens when you try logging in? Does admin / password work?
Message 4 of 4
Discussion stats
  • 3 replies
  • 1396 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
