Reply
help please
theerrol43
Follower
help please
Hello all,
I am needing help my router stopped working and I finally got it to factory reset. I hooked it up to my pc and followed the genie instructions. After I was done it said it was ready to use except I still have no internet access. When I boot up the  app it asks me to login which I do but the thing never loads in. Any information would be great. Thanks
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 3
Guru
Re: help please
Please post here in thie forum for your model router:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
Good Luck.
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v3.2.18.223/SRK30 V3.2.33.106)
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, RBK50, R7800, R7960P, EX7500/EX7700, XR450(v2.3.2.120) and WNHDE111
Message 2 of 3
Netduma_Alex
NetDuma Partner
Re: help please
Have you been able to connect to the router using routerlogin.net from your computer?
Message 3 of 3
Discussion stats
  • 2 replies
  • 434 views
  • 0 kudos
  • 3 in conversation
Announcements
