× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
how to fix xr500 to connect to internet
tech50
Follower
My expiernce with my XR500 netgear nighthawk gaming pro router was a storm that knocked out my router's connection to the internet. How do you fix this problem?: Problem solution i came up with was using my ac1900 nighthawk smart wifi router model r7000 to fix the problem at hand. After i fixed the problem that i had with my XR 500 gaming pro router is that i had to change it back to my ac1900 nighthawk smart wifi router model r7000 to fix the problem and there's never been a problem since
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 2
Netduma-Liam
NetDuma Partner
Re: how to fix xr500 to connect to internet
If you hook the XR500 back up again, I suspect you'll probably have connectivity again unless there was some damage caused by the storm. If you have any further issues let us know.
Message 2 of 2
Discussion stats
  • 1 reply
  • 671 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
