Reply
Highlighted
images sent from phone are failing and having issues
Hi All,
I recently purchased an xr500 router and I've been noticing an issue when sending/receiving pics via text message. When sending, it will stall for awhile and then fail. Sometimes it goes through after multiple reattempts, and sometimes I have to disconnect from the router entirely. Someone sent me a group of pics the other day and it sent me 7 copies over the course of 6 hours. A friend was at my house recently and seemed to be having similar issues on a different model phone (her issue was a text repeat in multiple conversations) so I'm looking at the router as the culprit. I have tested my internet speed and I'm getting the expected numbers (100 down / 6 up) and everything else seems to be working fine. I also do not see these issues when I'm not connected to the router. Does anyone know what could cause this or how to fix it?
phone model: pixel 3
friend's phone model: galaxy s10
router model: xr500
Firmware version: V2.3.2.56
Thanks in advance
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 33
Accepted Solutions
Highlighted
NetDuma Partner
Re: images sent from phone are failing and having issues
Could you try disabling MU-MIMO from there please - I'm not sure how new your phones are but might be they don't support it properly.
Message 30 of 33
All Replies
Highlighted
NetDuma Partner
Are you using Smart Connect for WiFi? If so I'd recommend disabling this and try connecting to the 2.4/5GHz band manually. Would also suggest using a WiFi analyzer to find the least congested channel and change to that. See if that helps.
Message 2 of 33
Highlighted
I disabled smart connect and connected to each band separately. They both do the same thing. A pic will send successfully at first (within the first 30sec to 1 minute of connecting) but if you wait, it will begin to stall and fail.
I checked the network monitor in the router UI and I have very little traffic happening at the time. There are only 2 additional devices connected to the 2.4 GHz and no additional devices connected to the 5 GHz
Message 3 of 33
Highlighted
NetDuma Partner
In WAN Settings toggle SIP ALG, does that fix it?
Message 4 of 33
Highlighted
I selected the box to disable SIP ALG and I'm still having the same issue
Message 5 of 33
Highlighted
Correction, it might actually be working after disabling SIP ALG. It failed at first but they seem to be going through on my last 2 tests. I'll test it again in the near future
Message 6 of 33
Highlighted
@Netduma-Fraser  - I just tested again and things seem to be working. Thank you very much for the help/guidance!
Message 7 of 33
Highlighted
NetDuma Partner
You're very welcome, glad to hear it is working. Thanks for posting an update.
Message 8 of 33
Highlighted
well @Netduma-Fraser  , I didn't want to have to revisit this, but I woke up this morning and sent a pic and it did the same thing again. Any chance you'd have another idea or area to check?
Message 9 of 33
Highlighted
NetDuma Partner
That's unfortunate, in the same WAN Settings changed NAT to Open. If it's caused by a port issue then that will resolve it.
Message 10 of 33
Highlighted
Thank you. I'll run several tests with that and report back tomorrow (so I don't jump the gun again :-P )
Message 11 of 33
Highlighted
Ok, so I tested several times last night and it's still acting up. For example, I sent a pic at 1:20 (that appeared to go through just fine, even though it was received ~20 minues later) and then sent another at 11:00 that failed. I re-sent it and it was received successfully after just minutes but then the recipient got another copy of it at 1am.
Message 12 of 33
Highlighted
NetDuma Partner
Okay could you try disabling QoS fully from the Anti-Bufferbloat 3 line option menu please and see if that works?
Message 13 of 33
Highlighted
I'm assuming you're talking about the area shown in the screenshot. It was already set to "never"
Message 14 of 33
Highlighted
NetDuma Partner
No, in the 3 line option menu in the top left of the panel. Click that and then there is a toggle to disable QoS completely.
Message 15 of 33
Highlighted
Ah, I gotcha. I'll make that change and report back
Message 16 of 33
Highlighted
Sorry for the delay. I disabled QoS completely and the issue is still present.
Additional (possibly pointless) details:
After disabling it, the failure took some time to reproduce (as it has with the previous changes), but I also had to shut off my power for an electrical repair. When going to shut off QoS, I had noticed that the Device Manager wasn't showing all of the connected devices in the house. After completing the repair and booting everything back up, I saw that the Device Manager was showing the correct number of devices and pics were being sent successfully for most of yesterday but started acting up that night (device manager still appears to be fine)
Message 17 of 33
Highlighted
NetDuma Partner
Thanks for the information. Very strange! Could you switch the router to AP mode please and try then? This will disable DumaOS entirely and therefore let us know whether it is something within DumaOS that needs to be fixed or something for Netgear to look into.
Message 18 of 33
Highlighted
If I change it to AP mode without a primary router in play, won't i lose all network connectivity?
Message 19 of 33
Highlighted
NetDuma Partner
What is the XR connected to? A pure modem or a modem/router that provides WiFi?
Message 20 of 33
Highlighted
just a modem (no wifi)
Message 21 of 33
Highlighted
NetDuma Partner
Okay yes in that case it wouldn't work. Do you have a spare router you could put in front on the XR to see if it works normally with something else between it and the modem. Also then you could try AP mode if it continues to not work.
Message 22 of 33
Highlighted
unfortunately, i got rid of the previous router once I got this one. I don't have the ability to test AP mode
I went ahead and reset the router to factory defaults to see if anything would change and I still have the issue. Would you like me to run through all the previously mentioned changes before anything else is done?
Message 23 of 33
Highlighted
NetDuma Partner
You can try but I don't think that would be necessary. Did you try using a WiFi analyzer to find the best channel just in case it is wireless contention?
Message 24 of 33
Highlighted
The WiFi analyzer showed the following results. Throughout the testing, I have tried switching between the two but got the same failures
780Mbps (5GHz)
192Mbps (2.4GHz)
Message 25 of 33
Discussion stats
  • 32 replies
  • 2594 views
  • 7 kudos
  • 2 in conversation
Announcements
