- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
open vpn with Xr500 netgear router - setup help
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello, I have been trying to find a free open vpn that i can use to access my home network outside but also use vpn at home to protect the connection line. the router i have is a net-gear xr500 gaming router and there have been some updates as of recently i noticed that we can use a vpn service now instead of a hybrid one which requires subscription. im confused on how to setup Open vpn. I have configured it on the Duma OS router xr500 enabled DDNS service which i use no-ip so that is good and created a hostname on the no ip site. after installing open-vpn to windows 10 pc that i am currently on and hit connect i get this error:
Also how do i connect to my home network from my android phone and also want to setup a ibm laptop i have as well to connect from outside.
are there any tuts for this configuration?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: open vpn with Xr500 netgear router - setup help
I would recommend having a look at page 173 in the manual regarding the VPN service: https://www.downloads.netgear.com/files/GDC/XR500/XR500_UM_EN.pdf
- Mark as New
- Bookmark
- Subscribe
- Permalink
ok thanks that worked for the setup on my android phone i was able to connect to the VPN and use my internet connection from 4g.. however how can i access my internal LAN computers ? from my phone , how do i access my PC's behind the netgear router what setting do i need to change or update DMZ ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
what is the main purpose ??
- Mark as New
- Bookmark
- Subscribe
- Permalink
What about them exactly are you looking to access? Their files etc? If so then Fraser's above suggestion will work. The purpose is to access your home network securely from outside of it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
correct but how do i access other computers behind the router with my android phone after i connect the openvpn app to my home network ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tried CX file explorer on my phone and selected Local network found nothing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
