- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
packet prioritization xr500 not working
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I'm trying to get packet prioritization working on my xr500, it doesn't recognize fortnite, it won't recognize the game packets no matter what I try, manual, auto and the "dumaOS classified games" all ignore the game packets.
I have tried downgrading to .120 and .114 but that didn't fix the problem, I did a factory reset from the dumaOS gui after each fw up/down grade and set everything up again from scratch but still can't get it to work, is this feature working for everyone else?
is this a known issue?
Thanks.
FW: V2.3.2.134
it is connected straight to the starlink dish poe adapter on the lan side, using a 3 foot cat8 cable.
Everything works except detecting and prioritizing game packets, it used to work just fine and I could see it prioritizing the packets but for some reason it stopped working, it could have been the update that killed it not sure though as it took me a while to notice it stopped working, none of my hardware has changed.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: packet prioritization xr500 not working
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the reply, I just tried making a manual QoS rule and adding my desktop as game console, I then went into the device manager and changed the same device (my desktop) to games console, I am still not getting prioritized packets when playing the game.
Is it working for anyone else on the latest patch?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The IP's match.
I was able to get prioritization to work as game console but I had to use the physical reset button on the router instead of reset to factory settings from the settings menu, after using the button to reset the router, I was able to get it to recognize packets by using the manual settings for game console and changing my device type to game console from the router device manager. This isn't the best solution either as it will prioritize all my pc traffic instead of just the game that I want but I guess it is better than nothing, I still can't get duma classified games to recognize my specific game, I wonder if they need to update something to get it the recognize the game executables that have probably all seen client updates and it seems from this forum that many games aren't detected any more.
Thanks for your help, I really appreciate it!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks, that fixed it!
Duma classified games is detecting my game again after syncing Device Manager, Geo-Filter and Ping Heatmap.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
