× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
router login
kidoryCharles
router login
How the **bleep** do you log into this piece of **bleep**? Every time I try routerlogin.net or .com, the **bleep**ing things tells me "
You are not connected to your Router’s WiFi network. To access routerlogin.net, your device must be connected to your Router’s WiFi network. Check your current connection and try again."
I am connected to this piece of **bleep** via ethernet, my desktop does not have **bleep**ing wifi!
Oh, and btw, you have no support! Stop advertising that yuou do. If you have support, how the PHuc do you access it, not from your webpages, that is for damn sure. All the tabs for support take you back to the same damn place, none to a telephone number, chat access or email!
Model: XR500| Nighthawk Pro Gaming Router
Message 1 of 4
Netduma_Jack
NetDuma Partner
Re: router login
Hi Charles,
Could you try this please:
  1. Power off your router, wait 30 seconds, then turn back on again
  2. Turn off your WifI on your PC
  3. Connect an ethernet cable from your PC into the router
  4. Open a browser and type in routerlogin.net and see if that connects
  5. If not, type in 192.168.1.1 and see if that connects
  6. If  it is still not connecting, could you open command prompt on your PC and type in 'ipconfig'. Press enter and then take a screenshot and upload here
My guess is either your WiFi connecting to another router, or you have some IP Address conflict
Message 2 of 4
kidoryCharles
Re: router login
Jesus, Mary and Joseph, can you not read? My desktop IS connected via ethernet, it DOES NOT have wifi
Message 3 of 4
Netduma-Fraser
NetDuma Partner
Re: router login
Access using the routers LAN IP and that will work. If you're not sure what that is open a cmd prompt on your PC and type ipconfig and press enter. The gateway IP is what you should type into the web browser.
Message 4 of 4
Discussion stats
  • 3 replies
  • 1282 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
