Wyzfar's avatar
Wyzfar
settings
Hello so i paid a guy to do some router settings for me for my ps4 i want an actual person that might understand more then he does to review these changes to see if i will actual be recieving a positive or possibly negative impact i dont care for "security" these settings are claimed to lower Latency/ping and better bullet Registeration on Call of Duty Black ops 4 Ps4 Pro the Photos below are the settings "changes" that were made
  • Hi there - the settings here will help you get an Open NAT. This is important in gaming because it allows you to connect to friends etc.
    But to reduce lag, you need to configure your Geo-Filter and QoS settings. Here are two easy-to-follow guides which walk you through how to do this:
    1. Geo-Filter Optimal Settings: http://support.netduma.com/support/solutions/articles/16000077072-dumaos-optimal-settings-guide-geo-filter
    2. QoS Optimal Settings: http://support.netduma.com/support/solutions/articles/16000077073-dumaos-optimal-settings-guide-qos
    If you get stuck at any point just let us know.
    • Wyzfar's avatar
      Wyzfar
      Are those ports setup correctly for bo4/ps4 is port 9307 tcp actually useful for bo4/ps4) in the wan settings is mtu 1473 actually better for gaming then 1500 and are all of those boxes that checked in wan settings actually useful as in better for gaming
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Disable port scan don't know why they've done that, that doesn't have an affect on performance. MTU is a myth that it gives you a better experience, it doesn't and actually if the MTU wasn't calculated correctly it can do more harm than good. They've added two other ports for the PS4 that is not necessary. All in all it's okay! Who did you purchase the service from? I would advise against that when you have Netduma/Netgear support available.
