- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
stack traceback error in logs
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
I see the following ERROR in the logs freqently. Should I be concerened?
Running V2.3.2.40, with an incredible uptime of 65 days with no incidents. To be honest, i could never run this XR500 for more then a few days without needing a reboot, but for the last couple months its been flawless without any changes done oddly enough. Maybe since the firewall can't restart thats why its stable? lol.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: stack traceback error in logs
- Mark as New
- Bookmark
- Subscribe
- Permalink
Has a factory reset been performed since v40 was applied. Might try this if you just updated to v40 and continued to use the router with out a reset. Seen it were lingering code can still remain until a reset is performed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I haven't done a factory reset in a while but can do that. Scared to touch it tho since its been so stable now.
I was mostly asking if the duma devs can make any sense or have seen such a nasty looking error?!?!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
First do a back up of the routers config to file before doing a reset. Then see what happens after the reset with out loading the config. See if the logs still report these errors. If not, then re-load the saved config from file.
