julio253's avatar
julio253
sustitución de router
hola buenas tengo el router xr500, puede el router xr500 substituir a mi router que me dio mi compañia telefonica? o necessita estar siempre conectado al router de la compañia.
Gracias.
1 Reply
  • Hey! Thanks for posting.
    The XR500 does not have modem functionality, so you'll need to have something upstream that performs this. If your ISP router/modem provides this, then you can connect the XR directly to this and you'll be good to go!
