× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
upgrade from 500 to xr 1000
nicey1958
Guide
 title says it.
Is it worth it or is it just for wifi 6?
cheers
Message 1 of 15
Accepted Solutions
Guru
Re: upgrade from 500 to xr 1000
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy. 📡
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
Message 13 of 15
All Replies
Guru
Up to you. If you don't have any WiFi6 supporting device, may wanna wait for WiFI7. No idea when that will appear for sale.
Message 2 of 15
nicey1958
Guide
thanks. Guess there's not much reason to then.
Geoff.
Message 3 of 15
Guru
I did happen to find a used XR1000 last year on Amazon for cheap. Something you can keep an eye on. Mine works great. I think I got mine for around $100 bucks. 😁
Message 4 of 15
Netduma-Fraser
NetDuma Partner
The upgrade would mainly be for the hardware improvements, the software itself wouldn't change too much.
Message 5 of 15
nicey1958
Guide
cheers... tbo.. i think that's what i might have been looking for..(h/w upgrade.. better perf?)... have been adding to house a lot recently... lots of 'so called smart devices.. even tho i'm not totally convinced they are that smart  '"alexa'''lol.. but anyway.... somethings felt a bit sluggish at times...  the xr500 has done its job very well in the past.. and not a problem.. but seems adding more things  maybe cause a bit of congestion???    anyways... its a new 'old thing'  i decided to play with.... and as said.. with none wifi 6 things and my age.. doubt whether ill get anything as well... plus a few more rj45 ports will be used behind the tv for sky/shield/dvd/TV plus hue and blink 🙂
cheers
Message 6 of 15
Netduma-Fraser
NetDuma Partner
If you have QoS enabled then no matter how many devices you connect it should continue to function in the same way so probably no need to upgrade really
Message 7 of 15
nicey1958
Guide
yup.. its enabled....   just seems iffy at times even on a wired connection but 99%  other times runs perfectly well. can't seem to pinpoint anything obvious   anyway.. not a lot of money spent so I'll always have a spare anyway..
Message 8 of 15
Netduma-Fraser
NetDuma Partner
Try experimenting with the Congestion Control percentages while set to Always to see what works best for you, might be that it just needs a bit of tweaking to work the best for your connection.
Message 9 of 15
nicey1958
Guide
970mbps down/120 up is my  internet connection. i adjusted bandwidth for the devices that seem to suffer buffering occasionally...   sky minibox and the shield  (both wired to upstairs -.  via  a magic 2 extender (i was thinking that might be one cause.. but its been fine in the past)  because they both suffer if I use the boxes them wireless as well. I keep trying in the meantime.
cheers
Message 10 of 15
Netduma-Fraser
NetDuma Partner
Don't adjust the bandwidth, that won't get rid of the lag, its Congestion Control you'll want to change specifically. Start at 70% and experiment in increments of 10%
Message 11 of 15
nicey1958
Guide
done.
cheers
Message 12 of 15
Guru
Enjoy. 📡
Message 13 of 15
nicey1958
Guide
i'd like to update.. since putting the xr700 in place of the xr500.. my woes have disappeared..... the only thing i have noticed is less or maybe evenly distributed cpu proc?  maybe that was the issue. quad core opposed to dual?   anyway..... I'm Happy.
Message 14 of 15
Guru
The XR700 HW is based off the R9000 I believe so comparatively, the 700 has more CPU power than the 500.
Glad you got it working.
Enjoy. 📡
Message 15 of 15
Discussion stats
  • 14 replies
  • 1909 views
  • 9 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
