Reply
Highlighted
xr500 LAN ports sometime will stop working
hi i need some help sometime my netgear nighthawk xr500 LAN ports stops working.wifi work fine not sure how to fix it. can anybody help me
Message 1 of 242
Accepted Solutions
Highlighted
NetDuma Partner
Re: xr500 LAN ports sometime will stop working
I've sent you a PM with firmware that may resolve the issue.
Message 2 of 242
All Replies
Highlighted
NetDuma Partner
Message 2 of 242
Highlighted
hi how can i do firmware update. not sure how to do it
Message 3 of 242
Highlighted
NetDuma Partner
Go to settings > administration > firmware update. Upload the firmware you downloaded then upgrade
Message 4 of 242
Highlighted
I need that firmware this is killing my security system in my house
Model: XR500| Nighthawk Pro Gaming Router
Message 5 of 242
Highlighted
Can you pm me this firmware also please
Message 6 of 242
Highlighted
how can i pm.or what ur email sorry im new at this.
Message 7 of 242
Highlighted
NetDuma Partner
Sent you a PM Coda with the firmware
Message 8 of 242
Highlighted
I'm having the same problem. Router in most recent firmware. Is this possibly and older more stable firmware?
Message 9 of 242
Highlighted
NetDuma Partner
Sent you a PM with firmware
Message 10 of 242
Highlighted
Hi,
I am also having the same problem. can you PM me the firmware?
Thanks
Message 11 of 242
Highlighted
NetDuma Partner
Sent you a PM
Message 12 of 242
Highlighted
May I please have the firmware also?
Message 13 of 242
Highlighted
NetDuma Partner
Sent you a PM
Message 14 of 242
Highlighted
Hello, mine has just started doing this today. Thought my PlayStation died.
Message 15 of 242
Highlighted
NetDuma Partner
Ok - I’ll send you a PM with the firmware to try
Message 16 of 242
Highlighted
May i have the update as well please?
Message 17 of 242
Highlighted
NetDuma Partner
Sent you a PM
Message 18 of 242
Highlighted
I just purchase this router 48 hours ago. I updated the firmware during setup.
So, shouldn’t my firmware be up to date?
I guess, like everyone else, can you please send me the firmware update that gets my LAN ports working again?
Message 19 of 242
Highlighted
NetDuma Partner
The latest firmware was only just released - could you please check which version of the firmware you're on? You should be able to get the latest version without us sending it via PM since it's now publicly available; you might just need to install it.
Message 20 of 242
Highlighted
Initiate
I just started having the same issue. My logs are filled with [DoS Attack: ACK Scan] alerts.
Message 21 of 242
Highlighted
NetDuma Partner
The 'DoS Attack' in the logs is almost certainly unrelated. It's just general white noise from the Internet (if you Google it you will see plenty of threads on this forum confirming it).
What exactly has happened? Has an Ethernet port failed on you?
Message 22 of 242
Highlighted
Initiate
Everything connected to LAN gets dropped while the worless works fine.
I just updated to the new firmware. Ill see if that solves my issue.
Message 23 of 242
Highlighted
Having the same problem with my router, using the latest available firmware XR500 V2.3.2.32
Every 24hours the LAN ports drop out and stay disconnected until I soft reboot the router.
This is a major issue for me as the computers dropping out are an essential part of the network and expected to be available 24x7 by other devices on the network.
Any advice on how to correct this issue, If we can't get this stable I will have to return the router to the store and go with another company.
Message 24 of 242
Highlighted
NetDuma Partner
On your Xbox please enable Energy Saving mode, if PS4 fully power off dont let it standby.
Reason being we've identified they affect the way the router connects when they wake up. Let us know if that resolves the issue.
Message 25 of 242
Discussion stats
Announcements
