BircanKiller
Jun 29, 2022Follower
xr500 geofilter problem on pc
- The geofilter is empty even though I tried all the suggested solutions on the xr500 router. I tried methods such as dmz, ip fixing, adding the device as console. warzone or other game, geofilter 1-2 servers sometimes find it, most of the time it doesn't. I am attaching screenshots below. Please help. I will have to return the product.
1 Reply
- Netduma-LiamNetDuma Partner
As you've got filtering mode enabled, Geo-filter will only spectate the connections and not interfere with them. If you want to ensure you're only getting connected to servers within the radius you've set, enable filtering mode.
