Reply
xr500 not showing moca 2.0 devices
jordy787
Guide
I have a xr500 and Just setup moca 2.0. I am using a linksys lgs105 unmanaged switch so I can connect my xbox and pc through moca.. anyways they dont appear to be displaying under devices on the router so I am unable to setup QoS and bufferbloat., any ideas?
Model: XR500| Nighthawk Pro Gaming Router
Message 1 of 12
Accepted Solutions
jordy787
Guide
Re: xr500 not showing moca 2.0 devices
I got it to work, I did not know I have to plug the moca ethernet into a specific port (port 5) on my unmanaged switch. All devices are showing after doing that. Sorry about that
Message 9 of 12
All Replies
Guru
Do they show up if directly conneced via LAN cable to the XR router?
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 2 of 12
jordy787
Guide
Yes, they do. I did notice they show up now but its under offline, my pc doesnt show a ip under device manager but my xbox does(router page). Do I need a managed switch for it to properly display and to configure with QoS?
Message 3 of 12
schumaku
Guru
That would be a subject for @Netduma_Jack @Netduma-Fraser @Netduma_Luke - technically the MoCa 2.0 is just yet another Ethernet bridge, the MAC addresses become visible to the router either already from the DHCP process, or at least once the router resp. the Internet is accessed. If they have access but don't show up - I would name this Voodoo.
No, a managed switch does unlikely help to make the devices visible. But here again, it would be interesting to hear what the Netduma geeks state about multiple devices connected over a switch to the DumaOS router.
Message 4 of 12
Netduma_Jack
NetDuma Partner
It makes sense the switch does not show on your device manager, but the devices connected to it should show as online (when they're online of course).
Are you getting Internet through each of them?
Message 5 of 12
jordy787
Guide
They do have access to the internet and work fine but just cannot configure anything since it says offline
Message 6 of 12
jordy787
Guide
Yeah I am getting internet through them and they work great. Just under the network map they are under the offline category
Message 7 of 12
Netduma-Fraser
NetDuma Partner
What firmware version are you on? Did it work at all on DumaOS?
Message 8 of 12
jordy787
Guide
Message 9 of 12
Guru
What is the Mfr and model# of the ethernet switch?
Message 10 of 12
jordy787
Guide
linksys lgs105. I had to plug my moca ethernet to port 5 and all other devices go to port 1-4.
Message 11 of 12
Guru
I would look at the user manual for the switch to see why port 5 is specifc for this. I presume it maybe the IN/OUT data traffic handling of some kind that port 5 does over the other ports. Glad it's working though.
Enjoy. Smiley Wink
Message 12 of 12
Discussion stats
  • 11 replies
  • 2252 views
  • 2 kudos
  • 5 in conversation
Announcements
