- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
xr500 question
- Mark as New
- Bookmark
- Subscribe
- Permalink
xr500 question
Do I have to disable my modems wifi?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: xr500 question
For what?
What are you trying to do?
If you're using the modem's (probably a combo device) wifi, you should have put the xr500 into the modem's DMZ if you want to continue to use it.
If that's not what you mean, a little more detail on what you're attempting and what issues you're running into would be beneficial.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: xr500 question
Every device seems to work fine with the xr500 wifi execpt for my brothers pc which seems to connect to the original modem via wifi perfectly fine but on the xr500 he gets no internet with a wifi ip configuation is invalid error
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: xr500 question
do you have the XR500's IP address set in the att devices DMZ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: xr500 question
I set it on ip passtrough DHCPS-fixed. The xr500 wifi is not working on only 1 device
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: xr500 question
I fixed it. I diagnosed the wifi card connected to the pc and it said the dhcp was disabled so windows fixed it itself. If i disable the modem wifi will i get faster wifi speeds with the xr500?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: xr500 question
Not necessarily. Just make sure the 2 wifi's are on different channels to prevent interference.
You want to make sure the XR500's IP address is in your router's DMZ. That'll allow you the fastest ping times.
