- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
xr500 r-app is not loaded yet. Please tray again in a minute
- Mark as New
- Bookmark
- Subscribe
- Permalink
Before starting I just want to say I have already searched the forums, I have already tried the fixes, I have already reset the router to default, and the router does not need to be updated as it is already up to date.
I am lost at what will fix this issue as I have run out of things to try in getting this fixed up. Post state the last update fixed this yet I am still getting this error. I purchased this router about a week ago from bestbuy so it hasn't been used a lot and is pretty much brand new. This error does not show up after the first setup is complete, but once I let it set for a few minutes and go back to editing it just errors out.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: xr500 r-app is not loaded yet. Please tray again in a minute
- Mark as New
- Bookmark
- Subscribe
- Permalink
No changes were made other than the basic setup on start, re naming two devices in the device manager and adding my playstation to the geo-filter. All areas work besides Geo-Filter, QoS, Device Manager, and Network Monitor. So basically the default items that are text based. One thing I did notice is in the installed R-apps you can't click any of the items to pause, play, or check the box to run on startup. They are all grayed out like the whole app system is not working.
- Mark as New
- Bookmark
- Subscribe
- Permalink
That's normal behaviour for the Installed R-Apps panel at the moment.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So far I have tried resetting it to default using the little reset button in the back. Along with trying different web browsers, going into incognito mode to make sure no plugins were causing issues. I tried rolling the update back and also re installing the update. Tried tweaking settings in the config area. Tried letting it load up for a bit instead of running directly to the area I want to look at. Tried leaving just the default setup and testing for awhile without editing. Tried rebooting the router (which works for 1 selection then after that it errors). It is as thou a part of the coding in the system is erroring out when it gets to a specific point in its operation.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yeah it ran me through the setup wizard when doing the reset on the back. I will try the in menu reset later tonight to see how that goes. I think this is hardware related thou in the coding that needs a fix.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not sure how or if i can edit old post but anyways. I was going through my log file area during my work break and noticed the following error going through. I put it in a pastebin so that it won't clutter the post.
Let me know if this could be the cause as it was working fine a moment ago when i logged in to check the log then stopped working moments later.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The error has been happening from the start. Though today when i noticed the error and it stopped working after those few minutes of working. Nothing new was added or changed. The only devices I have added are 3 phones (android), 2 ps4's, 1 xbox, 2 desktop pc's, google home device, and just my security cameras. However none of those were connected when I first set the router up other than my pc that was used to set the device up.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry for the delay as I have been working and some irl issues popped up I had to deal with. So I did what you said and the error did go away on the older version and the interface actually seemed a lot faster and more responsive. I tested it for a little to make sure it wasn't going to come back and nothing did. I then updated like you suggested and did a reset on the box within the admin area, letting it set for awhile and things seemed to be fine. There was one error within the QoS area when it was loading. Not the error stated above but "Error: The operation is taking longer than expected. Please briefly wait before using this R-App. Even thou I was in it moments earlier. This same error also happened in the Geo-Filter area.
Upon this I let it set for a bit longer before trying again and at first I thought it went away but even after it loaded that error came right back after about a minute on the page. To make sure maybe I just needed to re load the web browser. I closed it out fully and booted it up back to the router interface. Sadly this issue still shows.
But to give this the benifit I let it sit even longer and sadly the main error that I was having with the R-App is not loadded yet came right back. So it seems like its the firmware is causing the issues as the older version had none of these bugs from what I was seeing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I recommend opening up a support ticket and inform NG about this:
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Currently ive been using firefox to get into the web interface as chrome has been bugging from the start so I just moved over to that one instead of trying to figure out that issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I upped that and it does seem to load a bit better but sadly I still get the error. However thou the page for it is fully showing the info and not just erroring out like before.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you. I have been checking on it today here and there and oddly enough the errors are no more. I will try and get an exchange if that is what you suggest later this week on my day off. 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
