- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
xr500 router what settings to use for bandwidth allocation, qos etc
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a gigabit fiber connection 1000 up 1000 down...it seems at speedtest I avg around 400 down and 800 up.....what settings to use for bandwidth allocation, qos etc....what am I diong wrong?
see attached
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: xr500 router what settings to use for bandwidth allocation, qos etc
Disable QoS. QoS insn't really needed on a 1G ISP service line.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
ok when i did that and did speed test it seems slightly better with it on is that true? or placebo?
also why is my download 1/2 that of my upload?
400 down 800 up?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ethernet
Hmm
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would try a factory reset on the XR router and setup from scratch. Might walk thru the setup wizard, here it will detect the ISP speed, if it doesnt' detect it correctly, I would by pass the wizard, go in and disable QoS, do a full reboot of the XR and Fiber ONT and try a speed test via ethernet.
Try directly connecting to the ONT with out the XR router with the wired PC to check speeds here.
- Mark as New
- Bookmark
- Subscribe
- Permalink
by the way i just disabled qos a got a little better speeds...still dont know why download is half of uploas....I used the dumb switch method to bypass att pace router....Im using the above router and a tplink 8 port dumbswitch....im using the nighthawk router isnetad of the att pace modem
so if i go throught the dumb switch process agian.....after i rebooted the ont..it should help?
- Mark as New
- Bookmark
- Subscribe
- Permalink
so wheres my setup ont to tplink 8 port dumswitch... dumbswitch to wan port of night hawk router....
can i just plug my pc in to the dumbswitch ? it should see the ont correct? and test it that way?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Be sure to test at the modem first then directly behing the XR router. Don't speed test with anything in between.
Does this modem have a built in router?
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem.
I would use option #2 for the XR router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I already removed the att pace modem out of the equation..... I did the dumb switch method
https://www.dslreports.com/forum/r32491796-bypass-att-pace-gateway
so it goes from ont to nighthawk router, i fooled the ont to think the nighthawk is the modem...but im still getting dowload half of uoload? 400 down and 800 up? thoughts?
- Mark as New
- Bookmark
- Subscribe
- Permalink
ok so i can plug my pc into the dumb switch its a tp link 8 port ..which has the ont giong into it and then out to the nighthawk wan port...but when i plug my pc into the dumbswitch...how do i get it to connect to the ont and test that connection? what ip address do i need to force my pc too?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thats not going to work as the public IP address coming from the ONT to the Switch can only work for 1 connected device. So the XR won't connect directly to the ONT with out the switch?
You may need to contact the ISP and have them help you with this and see if they can get you set up better with speeds. They may required you to use the PACE router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Removed pace 500 down 900 up
So pace seemed to be holding it down
But why is my download about half of upload makes no sense
- Mark as New
- Bookmark
- Subscribe
- Permalink
