Orbi WiFi 7 RBE973
Reply
xr500 shows active device that we no longer have
jdklein
Tutor
Running #nighthawk #progaming #XR500 V2.3.2.134. Devices list shows a device brand that we no longer have, as still online with an active IP address. Ping to IP address times out however. Router has been power cycled many times. Device is part of a wireless bridge system where I replaced the manufacturer. Is it possible that the Duma OS kept the old device name associated with the IP address? Is it as simple as just renaming the device in the table? Thank you
Message 1 of 3
Guru
Re: xr500 shows active device that we no longer have
Could be. Or it could be an apple device using its random mac/ip address causing issues.
You have a ip address, do you have any devices using that ip address? (if you log into your devices to check the corresponding addresses)
Message 2 of 3
Netduma-Fraser
NetDuma Partner
Good advice above, it may be a different device with the old name, check the IPs your devices have
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 612 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
