jtabaco's avatar
jtabaco
Follower
Jun 23, 2019
xr700 10gb sfp+ configuarion wan or lan
I am in the process of getting 2gb up/down from my isp
They are providing a Juniper ACX2100 as the handoff. It has 2x sfp+ ports 1 to take the sm feed fiber and the second to disdribute to my network.
I bought the xr700 because I saw the sfp+ could be configured as the wan port and orginally was going to be limited to 1gb to all devices.
Now I will have a 4port 10gb sfp+ switch
I am hoping to connect the juniper to the switch and my one pc that has a 10gb nic
I would like to connect my switch to the xr700 but because I want it to be the router for my whole network I am not sure how to configure the sfp+ port.
If I configure as WAN then is their still a way for it to do nat, dhcp etc back through the switch?
1 Reply
  • FURRYe38's avatar
    Please review the user manual for the XR700:
    https://www.downloads.netgear.com/files/GDC/XR700/XR700_UM_EN.pdf
    Page 33 mentions specifying either the WAN RJ45 port or the SPF+ port on the XR700.
    You'll need to check with the SPF devices Mfrs support page and support site on how to configure that device.
