Reply
Highlighted
xr700 slow internet speeds wired
i just got my router and my internet speeds are cut more then half download is ussually 400 plus but it only reaches 110 i have disabled qos and its fine but if its enabled thats when it happens im not sure if im missing something here or whats happening
Message 1 of 6
Highlighted
Re: xr700 slow internet speeds wired
ok so i think i have figured this whole speed problem if your like me and boosted your internet speeds after you got your router then u need to go to your settings then setup wizard and run that it will retest your internet connection ......it detects your new speeds what its doing for me was based off my old speeds lol now that ive done this its getting the new speeds no more half speeds
Message 2 of 6
Highlighted
NetDuma Partner
Great to hear you resolved it! You can also go to QoS > Anti-Bufferbloat > 3 line menu in top left of panel and enter your speeds there
Message 3 of 6
Highlighted
oh so i didnt even need to do what i did i could have just put the speeds in that way?
Message 4 of 6
Highlighted
NetDuma Partner
Yes exactly but your way is correct as well just takes a little longer!
Message 5 of 6
Highlighted
Guru
New FW available:
https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-XR700-v1-0-1-10-Firmware-Available...
My Setup (Cable 900Mbps/50Mbps)>CAX80>XR450 v2.3.2.106(Router Mode)>RBK853 v3.2.11.2(AP Mode)
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, RBK853, R7800, R7960P,
EX7500/EX7700, XR450 and WNHDE111
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1002 views
  • 1 kudo
  • 3 in conversation
Announcements
