- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
xr700 what's the temperature recommendation ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
My XR700 has been providing irregular download speed. I have Xfinity gigabit.
Directly connected to modem, I get low 900s Mbps.
Behind the router I can get up to 800s Mbps. (QoS on, Anti Buffer on when needed, no hybrid VPN, no VLAN). However, more than often I get 300s Mbps typically.
I've tried different firmwares, factory reset, network card reset, but no luck.
I was wandering if it was hardware issue. And I recently learned about the Debug page that allows me to change fan speed. I've lowered the threshold. Since the CPU temps been less than 60, I get 800s Mbps more often. Please, see attached picture.
Here are my Qs.
1) Is the temperature in F? or C? I guess C.
2) What is the recommended temperature for optimized function of CPU and Wifi processors/antennas?
Thanks bunch.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Those temp values would be in C, not F.
Kind of high temps.
I would ensure the fan is running all the time to help save the life of the router. Heat can and will cause damage to electronics over time.
I keep a laptop fan cooler under my routers that I run.
Here are my Qs.
Thanks bunch.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: xr700 what's the temperature recommendation ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've tried QoS on/off and AntiBuff On/Off. DownLoad Speed irregularity continues to happen.
I just checked. Router CPU temp 53 (not sure still whether C or F, if I put my hand over the router it feels more like Celcius). Speed test shows 388Mpbs. Funny thing is that it will be 800s sometime later today.
I thought operating temperature was the environmental temperature where the router should be located at. If 0 - 40 C is what the machine supposed to be, then I should buy a dedicated Fan or AC for the router. 😕
Thanks again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
That's the only mention of temperature in the manual we have to go on but you could be right, it may not have any relevance to the internal temp. When the speeds are lower do you notice any reoccurring scenarios such as a certain device being used, a download etc?
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is Congestion Control Menu? I use this option to trigger QoS on/off,
Firmware version is XR700 V1.0.1.48
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, I used the anti-buffer menu to disable QoS.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you adjusted Bandwidth Allocation at all or is it simply set to default?
Do you know if you require PPPoE, VLAN or DHCP identifiers to get connected to the internet? If you haven't come across these before, it's likely you don't need them.
Are all devices connected to the XR700, then to the modem, or do some still connect directly to the upstream modem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Kind of high temps.
Here are my Qs.
Thanks bunch.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Bandwidth allocation: default
No PPPoE, VLan, DHCT setting required to be connected to the internet
All devices connected to the XR700, then to the modem (netgear CM1000 v2)
I ended up buying a 120mm fan, it's over the router. 140mm fan may fit as well. It blows some air to the modem cooling it mildly as well. I think stock fan is too small and inefficient.
Since then the temps are: CPU 34, 2G wifi 42, 5G wifi 36.!!!! (vs CPU 60s, 2G 80s, 5G 70s, previously with factory default). So far i am getting 800s Mbps (with QoS and anti buff on) vs 900s directly from the modem
So, if your device runs hot with sluggish speed, consider cooling it first.
Thanks
