- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
xr700
- Mark as New
- Bookmark
- Subscribe
- Permalink
So today I went out and bought a new xr700 from microcenter. I was wondering is there a beta firmware I can test with it.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have had that firmware for almost two weeks now I have been having issues with auto ping and Traffic boxs loading Have tried different browers have tired resetting and have done official firmware download and install once more have factory reset I also started having issuies with wifi turning on and off randomly now
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: xr700
Nothing as of yet. You might contact NG support to see if there is. NG doesn't post information on when FW updates are forth coming.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: xr700
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: xr700
Its all good I had to return router a bit ago. The UI became usable and kept freezing nonstop called netgear to try to troubleshoot it tech said there not able to, that i needed a higher level tech to troubleshoot and that the lv 3 tech was gone till Tuesday. No amount of reboots and pushing the reset button on the back of the router would bering it back to life. Now I have to wait over a week for the next one to come in the mail.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: xr700
netgear support is such a joke tho to bad netduma did not partner with asus or linkys.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: xr700
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: xr700
I did that and did another browser also tried another computer wireless lan and wifi and tried to use an IPad also. also ran cmd for ipconfig to get the Ip addres tired to go to the ip adress also along with the /debug page nothing would work. Its like it bricked while updating It ran great for a bit till it went to update.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: xr700
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: xr700
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: xr700
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: xr700
Got my new xr700 in the mail , so far so good its up and running .
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: xr700
So I ran into a slight " Glitch " my wifi lights on the router have stopped working I have reset and restarted not sure why they went out, all other lights are on and flashing . wifi is enabled also held the wifi button to try to restart it also. Its no big deal but kinda weird.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: xr700
So it is a glitch for sure after some trail and error I figured out what caused it and how to make it happen again. If turn your leds to disable blinking then you go to change wireless channels it knocks the lights out 100% on the wife lights. If turn Led back to blinking then disabled again they turn back on.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: xr700
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: xr700
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: xr700
Its all good. I am really enjoying the xr700 over the xr500. I have had the xr500 since the first day it came out .
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: xr700
I ran into something weird tonight I have restarted the router and xbox .My xbox is hardwired in on port 3 on the back of the router. When looking at QoS xbox is no longer making the high priority traffic to light up.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: xr700
Another strange thing is in device manger some of my devices are showing up with 1-2 ips each.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: xr700
That's strange - did you change the LAN IP recently?
Can you delete any of the devices with two IPs from your Device Manager?
Worst case, the solution here would be to factory reset. So please do this if you have not been able to clear the messages: https://kb.netgear.com/000053098/How-do-I-perform-a-factory-reset-on-my-Nighthawk-Pro-Gaming-router
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: xr700
No I did not and I can't delete them for some reason it just gives a error.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: xr700
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: xr700
so I have sb8200 cable modem hocked up to the xr 700 sfp+ port , then s8000 nighthawk switch on port 1 and 2, then I have a xr500 running off port 3 it has like 100ft lan cord. The xr500 is on the top floor of the house as a AP, then I have a ex7000 nighthawk extender in another room that is basically just for lan it has the wifi off on it. the extender is wifi connected to the xr500.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: xr700
In regards to the Xbox where is that connected in the setup?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: xr700
So after playing around with some settings for awhile some how My xbox ended up with more then one Ip address also. Thats what caused the problem I went in and made a static for xbox so far it seems like the QoS light is on again.
