- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
GS110TP Vlan membership
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
Set a trunk between GS110TP and Cisco 3750.
I need port 6 to be in vlan 50. Port 8 is the trunk to the 3750.
Port 8 with vlans 1, 50 set to Tagged
Port 6 with vlan 50 set to Untagged
Port 6 removed vlan 1
PVID is set to 1 cause vlan 1 is the native vlan on the 3750.
If I plug a pc in port 6 I don't get an ip from the dhcp server. From the 3750 onwards everything works fine - problem is from the netgear.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
@andmag wrote:Het a trunk between GS110TP and Cisco 3750.
OK. Is that "native" VLAN 1 tagged on that port, too?
@andmag wrote:Port 8 with vlans 1, 50 set to Tagged
Why oh why? You don't want the native VLAN ID 1 on that port, do you? Here is the mistake: Setting the PVID on port 6 to VLAN ID 1 will bring incoming frames into the VLAN ID 1 ... not as expected into the VLAN 50. Set the PVID for the access port 6 along with the untagged VLAN to the ID 50 and it will work.
@andmag wrote:If I plug a pc in port 6 I don't get an ip from the dhcp server. From the 3750 onwards everything works fine - problem is from the netgear.
Whatever a native VLAN is ... assuming the tagged / VLAN trunk config on the 3750 port is right ... probably yes.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: GS110TP Vlan membership
Thank you for helping me out. That worked of course
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
