- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Issue with GS808E - Nighthawk S8000 Switch Speeds
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hey everyone,
I, sadly, feel as though I am repeating the same issues that I had last year.
I spent the last week trying to figure this out using the netgear forums, reddit, and other messageboards all with no luck. I just got a Nighthawk S8000 switch and have been unable to get higher than 300 megs(often between 150-200) download.
My information:
- CM1000 Modem
- R8000 Router
- S8000 Switch
- Gigabit Internet service (Xfinity/Comcast)
- PC has a gigabit compatible port for ethernet
My modem gets the gig speeds when directly connected to my PC. When I connect my modem to my router, and my PC to my router, I get gig speeds. However, the S8000 switch I can't seem to break the 150-300 meg range.
I have tried all 7 ports on the switch, I have tried 4 different cables, I updated to the newest firmware (v1.7.1.0), I have tried a factory reset via the interface, I have also tried a hard factory reset using the button on the bottom. The speeds are the same every time. I event went back 1 firmware to version 1.7.0.7, and no luck.
In the interface it shows the 1000M speeds on the ports when set to Auto, but those speeds are not actually being received. I have tried speedtest.net and xfinity speedtest.
I'm honestly not sure what to do at this point.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Issue with GS808E - Nighthawk S8000 Switch Speeds
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Chrisenvoy wrote:Hey everyone,
I spent the last week trying to figure this out using the netgear forums, reddit, and other messageboards all with no luck. I just got a Nighthawk S8000 switch and have been unable to get higher than 300 megs(often between 150-200) download.My information:
- CM1000 Modem
- R8000 Router
- S8000 Switch
- Mostenirea
Try to change your modem hopefully this will work for you
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
