- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Lightning Vs S8000
- Mark as New
- Bookmark
- Subscribe
- Permalink
Lightning Vs S8000
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Lightning Vs S8000
sounds like the lightning won that round.
things you could try?
1. see if you have a matching power supply sitting around anywhere. its a fairly commoon one. Maybe only the power supply is bad and not sending enough voltage to it. (I wouldn't buy one)
2. I've never tried it but maybe you can use tftp/nmrpflash to re-install the firmware on it. Maybe the firmware is corrupt and creating a loop/stuck process.
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
