- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear Nighthawk Gaming SX-10 Switch 10GBE Heat Issues? gs810emx
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi All-
Looking for some help here. Here is my setup, SUPER basic, nothing fancy.
Router -> Netgear Switch -> PC 10GBE & NAS 10GBE NICs
I plug in the PC/NAS to the SX-10 swtch's 10GBE ports (1/2) and everything is default and DHCP. After about 30mins to an hour the switch 'disconnects everything until I unplug it and wait then turn it back on. On further checking the switch gets very hot so I assume its overheating and shutting down. I move the PC/NAS cables over to 1GBE ports and everything is smooth as butter and no heat at all on the switch.
This is a brand new unit, so I went a borrowed a friends Mikrotik 4port 10GBE switch and it does the samething. After about 30mins gets real hot and disconnects everything until its reset and cooled a bit.
I dont want to not use the SX-10 switch its perfect for me or even return it. Anyone know why it gets so hot? How can I fix this? What is causing it? Is this normal and the switch is cheaply built for expelling heat?
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear Nighthawk Gaming SX-10 Switch 10GBE Heat Issues? gs810emx
Using both the GS810EMX (SX-10) and it's GS110EMX sibling with 24*7 10 GbE links up. Both run on the warmer/hot side, no doubts, but both models are rock solid, also over the last summer. Aside, the GS810EMX is running cooler than the GS110EMX here - much better heat dissipation than the common metal wrap switch enclosure.
- Idle or full 10 GbE load until failure?
- Cable installation, total cable length?
- What devices are connected (PC 10Gb interface, NAS model)?
- Environment temperature?
- Located in free air flow, not on top of or very near to other hot operating devices, ...?
As the other vendor small 10GbE switch shows similar issues it's unlikley a one-off hardware issue - or you operate it at a very hot location.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Idle, I would just be surfing the net doing normal things and poop dropped.
2x Cat 7 - 10ft each cable. 1x for PC 1x for NAS and a 1x Cat 6 cable from a 1gbe port to router.
PC has a ASUS XG-C100C 10G Network Adapter Pci-E X4 Card with Single RJ-45 Port
NAS has a Synology 10Gb Ethernet Adapter 2 RJ45 Ports (E10G18-T2) - NAS Model - DS3617xs
Nice chill room, never hot. Under like 70 degrees mostly.
Attached under my profile name is a picture of it. Totally air free surroundings. From the picture I'm just using the 1gbe ports and no issues.
Let me know!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Complete obscure. Test using one 10G port only, either to the PC or to the Syno and see if the beast does shut-down in one of the combinations, too..
While talking - IEEE 802.3az Energy Efficient Ethernet.is enabled? And all flow control disabled? Current firmware is granted, your information is that complete.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I checked on the Switch and it was disabled, so I enabled it.
Yes, all ports have Flow control disabled.
Switch has latest firmware, PC has latest NIC driver, NAS's DSM is updated to newest and Router is latestly also latest.
I have just the PC plugged in and will run it for a bit then swap to just the NAS and see how our suggestion works.
