× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Nighthawk X6 + S8000 + Readynas 212 advice needed
Woodymanuk
HI All, I'm after some advice before I take my new toys out of the boxes.
I have a Nighthawk X6 + S8000 switch + Readynas 212, what's the best order to connect these.
Should I connect the Readynas to the X6 or the S8000?
Also once I connect the S8000 to the X6 would I only connect devices to the ports on the S8000 or can I still use the ones on the X6?
Thanks in advance.
Woody
Message 1 of 4
antinode
Guru
Re: Nighthawk X6 + S8000 + Readynas 212 advice needed
   You should connect everything directly to the "X6" (not an actual
model number). but when it runs out of ports, you're stuck with adding a
network switch (to the small one which is built into the router), and
using its ports.
   The switch will add a little latency, but you're unlikely to notice
it.
> [...] can I still use the ones on the X6?
   Yes.
Message 2 of 4
Woodymanuk
Thank you for that as wasn't 100% sure what's best, I have the following devices to connect.
Xbox one x
Virgin V6 box
Amazon 4k box
ReadyNas
Sonos Boost
Hive hub
Along with other devices via wireless.
Message 3 of 4
antinode
Guru
> [...] I have the following devices to connect. [...]
   What you have matters less than who talks to whom.  Ideally, the
fewer gizmos that need to handle the most data, the better off you'll
be.  But the overhead imposed by one more network switch might be very
tough to detect.
Message 4 of 4
Discussion stats
  • 3 replies
  • 2323 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
