- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Port based VLANs
- Mark as New
- Bookmark
- Subscribe
- Permalink
Port based VLANs
Hello
How to create a switch on this switch port based VLANs? is it possible at all? I need to add 1 common port to 2 vlan the easiest way 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Port based VLANs
The tagged GS724Tv4 does not support simple port based VLAN configurations, only standards compliant 802.1Q VLAN, see GS716Tv3, GS724Tv4, and GS748Tv5 Smart Switches Software Administration Manual p.87 ff.
Create a new VLAN on an unused ID, remove the ports you want to isolate into a dedicated VLAN from all current VLANs, add the ports to the VLAN required as [U]ntagged, and add the same VLAN ID as PVID to these ports.
PS. This is not Nighthawk Pro Gaming switch model - you will get better answers in the appropriate forum section Business Solutions - Smart-/Plus-/Click-Switches
