× Some paid Circle Parental controls customers may be showing free options only. Router firmware correcting this issue will be available ASAP. Visit Status.NETGEAR.com for updates.
Discussion stats
  • 4 replies
  • 551 views
  • 0 kudos
  • 2 in conversation
Announcements
Reply
Highlighted
Some Enquiry Regarding the VLAN packet go in and go out.
Hi, I'm new to VLAN and wish to justify my though about the packet go in and go out theory.
I have setup my sample VLAN network for testing and verify the VLAN is able to work. (Configuration Attached in VLAN_EachPort Setup.jpg)
Model: GS308T|NETGEAR® S350 Series 8-Port Gigabit Ethernet Smart Managed Pro Switch
Message 1 of 5
Highlighted
Re: Some Enquiry Regarding the VLAN packet go in and go out.
For Add on. This is my question. Could someone verify my statement written in bold is correct? I have attach the setup under the attachment too.
For each of the port, I have set all port is able to accept untagged and tagged frame packet by admit all, either the packet come in has tagged or untagged, it still able enter the port.
If I set the port as untagged, only packet without VLAN tagging able enter the port, tagged packet will drop before entering the port. Packet go out will be untagged too.
If I have set the particular port as Tagged, only the packet with VLAN tagging able enter to the particular port. Prior packet go out, it will become tagged..
Thank you!!!
Message 2 of 5
Highlighted
Guru
I would stay far away from any kind of non-standard asymmetrical VLAN configurations. Here what good friend wrote in the community recently:
"NETGEAR complies with 802.1Q standard and doesn't endorse / support proprietary asymmetrical VLANs with more than one untagged VLAN per interface."
Message 3 of 5
Highlighted
Hi. Thank you for your reply..
In fact I just want to known whether my statement is correct... Hope you can share what you thought to me..
Message 4 of 5
Highlighted
Guru
No, this depends on the Acceptable Frame Type setting.
Any frames on the VLAN  configured untagged will come out untagged.
Yes.
Message 5 of 5
