- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
issue with S8000
- Mark as New
- Bookmark
- Subscribe
- Permalink
issue with S8000
Hi All,
Looking for some advice with my S8000 switch which I have had connected up for sometime but have noticed that when I stream 4K it buffers.
Currently I have around 100MB download speeds with virgin media (Superhub 3), I have ethernet from Port 1 of the hub to Port 8 of the switch. I have smart tv connected to port 3 of the switch and Xbox one X connected to port 1 of the switch. (using all QED ethernet cables)
Last night when streaming UHD movie directly via Smart tv it contantly buffered. I then disconnected the smart tv from the switch and connected to directly to Virgin Superhub port 3 and the buffering stopped so is definately something to do with the switch.
Switch software updated to version 1.7.0.7
Both port 1 and 3 on the switch have the following settings
Speed - Auto
Linked speed - no speed
in rate limit - no limit
out rate limit - no limit
flow control - off
priority - critical
Any advice would be appreciated
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: issue with S8000
Curious as to why you did not plug the 4K TV into port 2 if you are streaming.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I wish I could help with this. My S8000 started have problems with dropped speed so I went with the GS908 switch. It is unmanaged so nothing to set up and now my network speed is what it should be on all devices and stays consistent.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks,
I have also posted in the virgin media comunity to see is its a settings issue in the hub that needs to be changed (I guess maybe to push all the data to port 1)
Not really sure how it works
- Mark as New
- Bookmark
- Subscribe
- Permalink
Every few months, companies like Netgear release the next generation of wireless routers that promise improved bandwidth, lower latency, and less loss. Although the wireless technology we have today is significantly better than what we had last year.
