Reply
Step by step double Nat Xbox one
Andysig
Follower
Hi
I have just purchased the above and all was working nicely, now I can not play or even access call of duty modern warfare.
I believe it’s because of this double Nat issue ?
As I’m not very IT at all, can anyone give me a step by step walk through how to get rid of this double Nat issue, I only want a basic wireless or hard connection nothing fancy.
Thanks in advance
Model: MR1100|Nighthawk M1 Mobile Router
Message 1 of 3
schumaku
Guru
Re: Step by step double Nat Xbox one
Call your mobile data provider, and request a a public routable IP address assigned to your router. Nothing you can do yon the router...
Message 2 of 3
Guru
so what is your full setup? You posted in the nighthawk pro gaming section but then listed the mr1100 in your signature.
What exactly are you running?
If you're going MR1000 -----XR***----> xbox, you would indeed be in a double nat.
If thats the case, either put the mr1000 in passthrough mode or put the XR*** in access point mode.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
1.4gig download/50mbps upload
We’re members of the public helping out on our own time.
Message 3 of 3
Discussion stats
  • 2 replies
  • 1695 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
