- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
1gb Spectrum with AX8
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just got wifi6 ax8. Before the installation, I tested and recorded signal strength, speed with the original wireless router that Spectrum provided and compared with AX8 after the installation. Only the signal strength is a little bit better. Overall performance is reduced than the original wireless router. Does anyone know what is the issue? I am trying to figure out Ax8 over mesh... thanks!!!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 1gb Spectrum with AX8
When you say "figure out ax8 over mesh"? Are you talking about smart connect?
Smart connect allows you to set one wireless name and the router will dynamically change what wifi band you need to be on.
This means devices that need lower bandwidth will connect to 2.4ghz and the higher throughput devices will be changed to the 5ghz band. That can be why devices on your stock perform faster as you have them always on the 5ghz. And they connect full speed at all times.
Plus do you have the QoS on for the AX8? it can change bandwidth/speed as well to optimize service or ensure that all devices are getting decent speeds.
There are many features with the AX8 you can play with to optimize speeds for your usage. You'll see the most benefit with the AX8 with multiple devices using it instead of just one device speedtesting it.
