Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
2.4 ghz wont turn off
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-03-02
09:19 PM
2020-03-02
09:19 PM
For some reason my 2.4 ghz is broadcasting even when it says its cut off. My guest network is off the wifi on the router says off the wifi in the menu says off but for some reason its up and running. Can someone tell me why?
Model: RAX40|Nighthawk AX4 4-Stream WiFi Router
Message 1 of 2
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-03-05
09:02 AM
2020-03-05
09:02 AM
Re: 2.4 ghz wont turn off
Fatraw1976, to stop the 2.4GHz radio from broadcasting, you may wish to test the following procedure. First, disable the 2.4GHz radio (ADVANCED | Advanced Setup | Wireless Settings | Enable Wireless Router Radio [be sure to also select “Apply”]). Second, reboot the router (ADVANCED | ADVANCED Home | Router Information | Reboot). Does this procedure succeed?
Model: CM1200|Nighthawk Multi-Gig Speed Cable Modem, RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 2 of 2
Announcements
