× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
5 GHz takes a few minutes to work while connected?
cyruslego
When i connected to 5GHz, my phone or other devices need to take a while (1-2minutes) to function even it saids connected, is it my settings’ problem? My 5GHz channel is on 153. Anything i should turn it on/off? Thank you!!
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 8
OBIHoernchen
Betreff: 5 GHz takes a few minutes to work while connected?
hey, which version of firmware is running at your RAX80?
Do u have smart connect enabled?
Message 2 of 8
cyruslego
The latest one i think (1.0.1.64), smart connect is off
Message 3 of 8
OBIHoernchen
I can recommend a downgrade to the .62, .56 or .40 only - the .64 is buggy.
https://www.netgear.de/support/product/rax80.aspx#download
Message 4 of 8
cyruslego
Ok i’ll try to do that, besides that what problems do u think may cause this issue??
Message 5 of 8
OBIHoernchen
Hey, I think this Firmware-version is immature.
The .62 makes problems here, too. You can use .56 or .40 from the link above. I use the .56 now 😉
Message 6 of 8
cyruslego
So i need to download the firmware to a usb and plug it to the router right?
Message 7 of 8
OBIHoernchen
Nope. Do that:
- Download the firmware u want (.zip)
- unrar the zip (u need a .chk)
- browser: routerlogin.net
- go to: advanced
- administration
- Router Update
- "browse" and open to the .chk
- "upload" and wait few minutes
- (to get a clean install du a factory reset after flashing the firmware. You must set settings new then.)
- disable the automatic update function at "Router Update"
Good luck 😉
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1713 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
