Reply
Highlighted
AX 12 Frequently disconnect from the unconnected network
v1.0.1.122 is the latest firmware. I cannot connect to the network, but the Wifi is connected normally. If there is no network, you need to restart the router to operate normally. The same problem exists when restoring factory settings.
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 2
Highlighted
NETGEAR Moderator
Re: AX 12 Frequently disconnect from the unconnected network
Hello Xiong,
May you revert to the previous firmware version and see if the issue persists.
Thanks,
Christian
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 155 views
  • 0 kudos
  • 2 in conversation
Announcements
