× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
AX12 AX6000 Wifi Router losing password on devises
rctvideo
On several occasions one of two of my devises will not connect to the Wifi.  When I connect is says it has the incorrect password.  The devise connected before with the password that i installed.  I will then sign in with the password and a messages comes back that it is the incorrect password.  I know that it is 100% correct and other devises are stilled signed into the wifi.
The router will not let me log in either.  I have to turn off the router and then back on.  It will then let me sign in to the wifi with the password.
This is happening at least once or twice a week.  What is the issue?
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 17
Accepted Solutions
MTje
Initiate
Re: AX12 AX6000 Wifi Router losing password on devises
Yes it works, the problems are solved
Message 10 of 17
All Replies
VelkySyr
Tutor
I am having the same issue with my router as well.  This really needs to be addressed.  While there is a workaround, it is not an acceptable way to have to manage the router,  Other than this, which I do consider a big issue, the router is excellent in terms if every other aspect of its performance.  NetGear, please get back to us on this,
Message 2 of 17
Christian_R
NETGEAR Employee Retired
Hello rctvideo & VelkySyr,
A few questions for the both of you:
1. Is the issue occurring on all devices?
2. Have you tried factory resetting your router and going through the setup instructions again?
3. You may also try forgetting the network on your wireless device and reconnecting
4. What firmware version is your router on?
~Christian
Message 3 of 17
MTje
Initiate
I have exctly the same problem, last 3 days, our iphones (6, 7 plus), and my galaxy note 8 and ipad pro (2018) all latest firmwares lost their connection and couldn't reconnect due to their passwords being incorrect, which I am sure wasn't the case, after several times of retrying it worked again.
Router Firmware Versie V1.0.1.90
Message 4 of 17
Christian_R
Hello Nighthawk AX Community,
We currently have a trial firmware that may help resolve this issue. If you're interested, please send me a message.
Christian
Message 5 of 17
rctvideo
Sure.  I will try the firmware upgrade
Message 6 of 17
rctvideo
1. No just a few.  Other devises work fine.
2. No this has not been tried
3. Tried
4. Latest V1.0.1.90
Message 7 of 17
Christian_R
rctvideo,
Thanks for confirming. I have sent you a message with the trial firmware.
~Christian
Message 8 of 17
medic4085
Christian_R,
Has anyone been able to confirm that the trial firmware worked?  This was not a problem for me until about 1 month ago.  Now I have to keep rebooting the router and it will fix the issue for a few days.
Message 9 of 17
MTje
Initiate
Message 10 of 17
Streaky
Hello, I have had this problem for some time on my router, an it's also happening to visitors trying to access my home WiFi.  I have the latest firmware (1.0.1.56) - is this beta firmware out of beta yet?  I'd dearly love to make this password issue go away.
Streaky
Model: D7800|Nighthawk X4S – AC2600 WiFi VDSL/ADSL Modem Router
Message 11 of 17
Christian_R
Hi Streaky,
Would you mind confirming the model number of your device (eg. RAX120)
Thanks,
Christian
Message 12 of 17
Streaky
Firmware 1.0.1.56
Message 13 of 17
Streaky
And the model is in my sig above (the post to whoch you replied): D7800|Nighthawk X4S – AC2600 WiFi VDSL/ADSL Modem Router.
Message 14 of 17
Christian_R
Hi Streaky,
Thanks for getting back. I would recommend posting your issue(s) on our DSL Modems & Routers board and a community member will reach out to you there. You may use the link below to navigate to the board.
https://community.netgear.com/t5/DSL-Modems-Routers/bd-p/home-dsl-modems-routers
Christian
Message 15 of 17
Lambogini69
I am having the exact same issue with my RAX120
Firmware V1.0.1.90
Is there a release that is going to go out to fix this officially or are we needing to get the trial version still?
Message 16 of 17
Christian_R
Hello Lambogini69,
Welcome to the Community! May you update to the latest firmware version and let us know if your issue still persists.
https://kb.netgear.com/000061295/RAX120-Firmware-Version-1-0-1-100-Hot-Fix
Christian
Message 17 of 17
Top Contributors
Discussion stats
  • 16 replies
  • 4936 views
  • 2 kudos
  • 7 in conversation
Announcements
Orbi WiFi 7
