Reply
AX120 Link Aggregation drops speed until reboot
gyifan
Initiate
Similar to another thread, I found the internet speed drops from 900+Mbps to ~5Mbps everyday. To fix the issue, I have to restart the router. Then the speed will come back to normal (900+Mbps).
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/rax120-dropping-connection-speed-u...
Based on this thread discussion a year ago, I had to disable link aggregation. I'd like to check if anyone has gotten Link Aggregation to work with their AX routers.
Thanks!
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 3
bpob1977
Re: AX120 Link Aggregation drops speed until reboot
Nope, still a problem. For that matter, IPV6 doesn't work right with WAN aggregation either.
Message 2 of 3
gyifan
Initiate
Ah. That's a bummer. I was hoping to get more bandwidth though LAG. Guess I would have to hope the next firmware update will improve then.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 302 views
  • 1 kudo
  • 2 in conversation
Announcements
