Reply
Sana
AX6200
I bot RAX78 very recently. My existing TP-Link Kasa Smart Dimmer Switches (3) could always have intermittent connection problems every 10-30 secs. So it's become issue with voice controlling either thru Alexa or Home. Please guide me
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 3
Christian_R
NETGEAR Moderator
Re: AX6200
Hello Sana,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
Message 2 of 3
Sana
Re: AX6200
Hi All,
I contacted TP=Link Kasa for their expert opinion.
They suggested - i un-Check the Smart Connect and re-start the router.
It went off very well.
Hemanth
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 134 views
  • 0 kudos
  • 2 in conversation
Announcements
