- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
AXE11000(RAXE500) - Nighthawk Tri-Band WiFi 6E Router ~ Port Forwarding Error in Firmware
- Mark as New
- Bookmark
- Subscribe
- Permalink
I was just wondering if anyone could forward this issue to the engineering team as it is a major problem with the Port Forwarding feature. During my search for a solution, I have come across several posts and questions similar to mine for previous routers that were never resolved. Any solution tells them to factory reset the router, which isn't a permanent solution, just a temporary quick fix.
Here is the issue: After port forwarding a couple of ports to my devices, the router Port Forwarding page will stop displaying any ports that are already forwarded.
- The Port Services are no longer visible on page to view the ports currently in use by the customer or even let the user delete them.
- The router's internet connection becomes very slow & unstable, where not a single device connected to my router (over 30+ devices) can mantain a steady connection for longer than a minute. When I plug in directly to my modem, it works just fine.
- If you try to add a Port already added to the invisible list, it won't let you because it is already in use. (obviously, but just thought I would mention my proof of the "invisible" list)
- The router's debug page also shows the CPU Load increasing sporadically from all 4 being in the 2-3% range before the error occurs, then all 4 being in the 10-20% range or even higher sometimes soon after the error happens.
- After resetting the router, I can add the services again to the ports, but then it breaks once again before I can even finish adding them all.
As a student myself studying Computer Science, it seems to be faulty coding in the firmware when handling these port forwards that is causing an issue and I have seen similar customers online asking for help with this issue as far back as 2013 in another post on this forum. This issue seems to be a constant one in all netgear routers based on my research with no current resolution offered besides factory reseting. Could we please get a more permanent fix in the form of a firmware update? Thank you!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AXE11000(RAXE500) - Nighthawk Tri-Band WiFi 6E Router ~ Port Forwarding Error in Firmware
seems like GUI issue. Interesting to look into this.
