× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Ax12
Medamed
Follower
Ax12
Wifi 6
Bonjour voila j'ai acheté se nouveau modèle wifi 6 ax12 et ma connexion est en fibre optique Ma qestion et : Comment branche mon wifi 6 au fibre optique Merci
Message 1 of 2
Guru
Re: Ax12
Usually your ISP supplies you with either an ONT (optial network terminal) that you connect to or a gateway device. Have they done so?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 459 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
