- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Ax8 issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ax8 issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ax8 issues
What modem are you using?
Waht firmware is on your router?
Are all the devices having issues or just specific ones?
Is the issue isolated to wireless devices or do wired have the same issue?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ax8 issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ax8 issues
when you get home, the model numers might help.
You can also try disabling AX on the RAX. Some have had help with that.
The RAX devices are pretty new and have been getting a few updates. Some have responded well to factory resets after the updates.
those that continue to have issue, you can try downgrading the firmware to see if it helps.
Just make sure to do any firmware changes over a hardwired connection.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ax8 issues
I decide to do a factory reset. When i got home my wife was having issues with the wifi so reset was in order. I also disabled the AX. hopefully this helps or i am sending it back.
- Mark as New
- Bookmark
- Subscribe
- Permalink
