Orbi WiFi 7 RBE973
Reply
CAX80 WiFi Network resetting
KasarIG
Hello, I have a CAX80 Cable Nighthawk router that we bought about a year ago.  (Hardware version: 1.01, Firmware: 2.1.1.4, Cable Firmware:1.02.08 are up-to-date)
It has worked great, solely using WiFi up until this week.
It has now twice reset the WiFi Network, which was renamed to "Broadcom" and was unsecured.  I am able to go in and reset the settings, but I have no idea why it is doing this.  Has anyone else experienced issues like this and have any ideas what is going on?  There have not been any power outages.
Message 1 of 7
Guru
Re: CAX80 WiFi Network resetting
Do you have a screen snip of the cable connections page and the event logs?
I've seen ISP's trigger a new firmware install/reset process.
Message 2 of 7
KasarIG
@plemans I just found where the event log is, but it only goes back 6 hours or so to this morning... If this happens again I'll grab the info from it.  I've included a screenshot of the cable connections page.  Everything past Channel 6 is "Not locked" showing the same information,
Message 3 of 7
Guru
photos have to be approved by a moderator. you can click on choose file and add it th at way
Message 4 of 7
KasarIG
Alright, as a file!
Message 5 of 7
Guru
You should save a back up configuration to file for safe keeping. Saves tine if a reset is needed.
Message 6 of 7
Guru
the file you sent only shows 1 downstream locked or even visible.
Might be worth opening a support case with since usually if they're not locked, they still show up.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1121 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
