× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Can I use a Rax200 with Orbi?
MoonBlossom
Tutor
We have RAX200 and over 80 devices. I think we need a mesh network. Can we use the Orbi or any WiFi 6 mesh system with the RAX200 router or do we need to get a mesh system and sell the router? Thank you for your help.
Message 1 of 5
Accepted Solutions
Guru
Re: Can I use a Rax200 with Orbi?
Either could work. You could shut off the wifi on the rax or leave it on.
I usually leave it on and just make sure its on different channels than what the orbi is using to prevent interference.
Message 4 of 5
All Replies
Guru
Either route would work.
I've went with my RAX200---->orbi system before. It worked great.
I used the RAX for the devices close to the router and let the mesh handle things on the peripheral.
If you go that route you just need to put the mesh system in access point mode to prevent a double nat.
Message 2 of 5
MoonBlossom
Tutor
Would the RAX stay as ethernet only, while the orbi works for WIFI? I'm sorry I'm new to this. Thank you 🙂
Message 3 of 5
Guru
Message 4 of 5
MoonBlossom
Tutor
Thank you so much!!!
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1829 views
  • 3 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
