× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Cant connect to Nighthawk MK63 mesh wirelessly on any device
auscyber
Follower
I have reset my router three times to factory settings. restarted it even more. and i cant connect any devices to it wirelessly. over ethernet its fine and i have internet access. just no wifi. it just shows this then instantly disconnects
Message 1 of 2
Christian_R
NETGEAR Employee Retired
Re: Cant connect to Nighthawk MK63 mesh wirelessly on any device
Hello auscyber,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
Message 2 of 2
Discussion stats
  • 1 reply
  • 484 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
