- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Desktop PC won’t connect to RAX 75 5ghz
- Mark as New
- Bookmark
- Subscribe
- Permalink
If I change the wifi card settings to 20 mhz channel for 5 ghz it will connect but this defeats the purpose of having wifi 6 does it not?This has been going on for months and its honeslty frustrating. Ive tried different intel drivers and changing settings around on the router and nothing. Getting to the point if its not working soon I will just return the router to Costco and go with a different brand.
Any help? solutions? last ditch efforts?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Desktop PC won’t connect to RAX 75 5ghz
What driver version is the AX200 on?
- Mark as New
- Bookmark
- Subscribe
- Permalink
For intel ax 200 i am currently running verison:
22.0.0.6
I have tried previous driver versions already on my previous desktop pc using the ubit wifi 6 card and it didnt work.
For nighthawk router im using verison 2.7.0.27.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Nighthawk router is on 1.0.3.102
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does it connect if AX is disabled on the router?
Have you factory reset the router and reinstalled it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
With AX disabled on the router it still does not connect.
Doing a router reset hitting the reset button on the back and going through the setup process did not fix anything either.
Intel had new drivers for ax200 also I noticed this morning.
Update drivers to 22.10.0.7 and still no internet access on 5ghz network with my desktop.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It makes me suspicious of the card. I know there was a different device with issues but you don't have that one to test anymore.
I have an intel AX200 and and AX210 and they both connected.
The AX200 I got when drivers were still new and it had issues, disabling AX would allow it to connect and there was a pretty quick firmware change and it worked with AX after that.
Other than the 1 other, all of your other 5ghz devices work?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just took my xfinity wifi modem/router out of bridge mode and tested that 5ghz connection and it works perfect with ax connection also. Think im going to return the netgear router back to costco look into a different one.
