× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Different Netgear network appears than on label (AX3000)
matt91486
Follower
Hello. I'm trying to set up a new router. The sticker on the router says it should appear under Netgear85, and provides a password. This network does not appear. However, when the router is connecte, a different network (Netgear88) appears. The password provided does not work with netgear88. This network disappears when the router is unplugged, and the correct network never appears.
How do I solve this conundrum?
Model: RAX40|Nighthawk AX4 4-Stream WiFi Router
Message 1 of 2
antinode
Guru
Re: Different Netgear network appears than on label (AX3000)
> [...] a new router. [...]
   If it's actually new, hence under warranty, then I'd complain through
official channels: http://support.netgear.com/
   If it's out of warranty, and someone just put a differently
programmed board behind that label, then you might be stuck with an
unknown default wireless-network passphrase (or two).
   So long as you can get to the router's management web site, you
should be able to set the SSID(s) and passphrase(s) to whataver you'd
like.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 543 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
