- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Firmware update issue NETGEAR RAX35 Nighthawk AX4 4-Stream WiFi 6 Router
- Mark as New
- Bookmark
- Subscribe
- Permalink
I currently have a help desk ticket open and there has been no reply. I updated the router with the latest firmware update V1.0.3.80 and it wont save the changes that are applied on the router, especially the channel, mode levels, and even selecting WPA2/WPA3 settings. I have also downgraded and reupgraded the firmware. Using the previous firmware seems to solve the issue. Any ideas on how to fix this problem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Firmware update issue NETGEAR RAX35 Nighthawk AX4 4-Stream WiFi 6 Router
during any of these firmware changes, did you factory reset and do a clean install on the router? If the firmwares changed enough, a factory resets clears old/bad settings. its also why a clean install (not from backup) can help.
I'd try that if you're having issues after firmware changes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
