Reply
Highlighted
Apprentice
Guest Wifi SSID
Hi,
Would that be possible to set the same guest wifi SSIDs, such as for non-guest, in both 2,4Ghz and 5Ghz in the next firmware ? (and not SSID_name and SSID_name-5ghz)
Model : RAX40.
Many thanks.
Benoît
Model: RAX40|Nighthawk AX4 4-Stream WiFi Router
Message 1 of 4
Accepted Solutions
Highlighted
Apprentice
Re: Guest Wifi SSID
Done thanks.
So you mean that's it's not a bug but a feature request Smiley Wink
Best,
Message 4 of 4
All Replies
Highlighted
Apprentice
Re: Guest Wifi SSID
Current Firmware version : v....60_1.0.1
Message 2 of 4
Highlighted
Guru
Re: Guest Wifi SSID
you can try suggesting this in the suggestion forum.
https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
CAX80-> RBK53-> GS716v2-> TP-Link M9Plus
Message 3 of 4
Highlighted
Apprentice
Re: Guest Wifi SSID
Done thanks.
Best,
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 723 views
  • 2 kudos
  • 2 in conversation
Announcements
