Reply
Highlighted
Has Netgear removed firmware 1.0.1.90?
I do not see firmware 1.0.1.90 for download for RAX120. Has Netgear removed it? All I see is 1.0.0.84.
Thanks,
Arun
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 27
Highlighted
Re: Has Netgear removed firmware 1.0.1.90?
I see that too.  Im not haveing any wifi issues with 1.0.1.90.  Should I downgrade it to 1.0.0.84 or stay at  the 1.0.1.90?
I know there is an issue with selecting the WAN port to 5g.  It will rebot your router in bridge mode and lock you out.
Any help will be nice.
Message 2 of 27
Highlighted
Guide
i notices the same
should we downgrade or should we wait for an update
as i am not happy with 1.0.1.90
is there any new beta we can try
as i am having problems with intel ax200 card
Message 3 of 27
Highlighted
NETGEAR Moderator
Hello Nighthawk AX Community,
We have removed the the following firmware version off our support site. We currently have a trial firmware for the RAX120 and if you're interested, please send me a message.
Christian
Message 4 of 27
Highlighted
Guide
yeah i am interested
Message 5 of 27
Highlighted
No thanks, I will pass. Stability is extremely important to me. All my security cameras and alarm system and TVs and phones and laptops are connected via WiFi. In one year, typically 50TB of WiFi data passes through the router. Cannot have instability. 1.0.1.90 was really bad firmware. Glad that it was removed.
Message 6 of 27
Highlighted
Prodigy
If stability is key, unfortunately probably not best to get a new model (regardless of brand) so soon after release especially with a new WiFi standard that’s only now getting a final draft specification, so not everything maybe supported in earlier draft version based devices like this one. To top it off it takes a while for firmware to stabilize as some of the issues also need to be fixed by the actual chipset manufacturers themselves. Basically early adopters are paying to be testers.
Message 7 of 27
Highlighted
Guide
for me i am always a beta tester for everything i will take some bugs just to get the latest futures
and if i see any bugs i just report them
Message 8 of 27
Highlighted
Retired_Member
Not applicable
Should we downgrade? I’m not really have any issues with got 90.
I wouldn’t mind trying the beta firmware. If it doesn’t brick the router.
Message 9 of 27
Highlighted
Guide
if 1.90 work for you with no problem just keep it
for me i had a problem with one wifi card that was dropping speed connection every 2H
in 0.84 the drops still happened but less frequently like every 5H
i am on 1.97 from this morning untill now there were 0 drops so far
you should wait for next stable to be on the safe said
Message 10 of 27
Highlighted
I was having problems with the AX200 with 1.0.1.90 as well. The speed would randomly go to a crawl.  Disconnecting and reconnecting fixed it for another random period of time.
In looking for a revised firmware I too found 1.0.1.90 was gone.  I downgraded to 1.0.0.84 and my AX200 random speed drop problem has been fixed.
Up until I upgraded my client to an AX200 this firmware was working fine as far as I could tell.
I also tried the Killer ax1650 card with the same symptoms with the 1.0.1.90 firmware.
Message 11 of 27
Highlighted
I'd be interested in trying the trial firmware as I'm now testing 2 AX clients and the 1.0.1.90 firmware was not working well - randome speed drops to about 1/90th the speed till disconnect/reconnect.  Firmware 1.0.0.84 is working well though.
Message 12 of 27
Highlighted
Netgear,
VERY disappointing almost 6 months from 1.0.0.84 and two or three f/ws pulled during this duration. How about new firmware for wifi 6 certification?
Scott
Message 13 of 27
Highlighted
Hi Christian - I'm having the issue with my router dropping PW info (forcing reboot several times a week)... running the firmware v. 1.0.1.90.  Need instructions/link to download version of firmware that will fix this problem.  Thanks!
Message 14 of 27
Highlighted
Guide
I'm interested in the new Beta, can you provide me with a download link
Message 15 of 27
Highlighted
Netgear,
Please send me the link for the Beta Rax20 firmware.
Thank you
Scott
Message 16 of 27
Highlighted
Hi Christian! I would like to try the beta firmware for RAX120. Thank you.
Message 17 of 27
Highlighted
Hi Chrisitan,
I would also like to try out the beta firmware. I did PM you a couple days ago but not sure if you check your inbox frequently. Thanks for any help.
Message 18 of 27
Highlighted
hello, i saw your post about geting in on a new trial version of the RAX120 FW. if possible i would like to get it for my router.
Message 19 of 27
Highlighted
Hello! Please send me the link for the Beta Rax20 firmware.
Thanks so much!
Message 20 of 27
Highlighted
Prodigy
The 1.0.100 released and immediately I noticed under the "Basic" section you cant click on Internet setup or Wireless Settings, you can only get to the via "Advanced" tab. Looks like there is some formatting error which deleted the buttoons but left the UI placeholders for them. And the Nighthawk app still cant detect connected devices.
Message 21 of 27
Highlighted
Tutor
I'd love to try the beta firmware. My rax120 drops to about 20mbps after it is up for 24 hours. I constantly have to reboot in order to get gigabit. Wan port aggregation on, if it matters.
Message 22 of 27
Highlighted
HI Christian,
I'm having issues with my RAX120 router and would like to try the latest beta trail firmwarfe please send me the firmware or the link to download.
Thanks,
Buvan
Message 23 of 27
Highlighted
I have firmware 1.0.1.90 installed currenlty and I am having issues with browsing and downloads to my AppleTV. I see that you have offered let owners of the RAX120 to apply a trial firmware version. I would like to also try it.
Perry
Message 24 of 27
Highlighted
NETGEAR Moderator
Hello cadmanp,
Thank you for your interest. We are no longer running a trial firmware for the RAX120 as the official firmware is now available. I have linked the release note to the hot fix firmware v1.0.1.100.
https://kb.netgear.com/000061295/RAX120-Firmware-Version-1-0-1-100-Hot-Fix
Christian
Message 25 of 27
Top Contributors
Discussion stats
Announcements
